Sansa clip won't turn on or wont be recognised by computer
I have tried the usual fixes but my clip will not turn on or be recognised when I plug into computer via USB.
Any help appreciated.
Unless you list (in detail) those ‘usual fixes’, no one here will know what to suggest. :wink:
Better to give all the information you can off the bat, rather than going back-and-forth playing 20 questions. That just wastes everyone’s time.
Held power button up for 3 minutes
Held volume + while plugging into usb
Held centre button while pluging into usb
Thanks
Actually everything here:
http://kb.sandisk.com/app/answers/detail/a_id/9/related/1
and here:
http://kb.sandisk.com/app/answers/detail/a_id/188
Anyone??
Is there somewhere I can send to get repaired in the UK?
Is it an original Clip or Clip+?
How long have you had it?
Might it still be under warranty?
Have you tried different USB ports and/or a different computer?
Have you tried an AC-USB charger as opposed to your computer?
The original Clips had a problem with badly soldered battery connections.
Could also be you have a bad cable.
Nobody repairs these things; it would cost more than buying a new one, even in the UK.
Just had the same problem. Nothing worked till i used an AC to USB adapter. Maybe the added juice that you don’t get when just plugged into your PC ‘jumps’ it…i dunno, I am just happy it started. Now I am off to back all that music on to a harddrive.
