Hi there. I ordered a 4gig sansaclip+ and I’ve been struggling with getting the MicroSDcard to work at all. From looking around various forums, it seems this is a fairly common problem, but I haven’t seen one solution. I tried emailing Sansa support, but Ive had no response.
-The Player is running Firmware 01.02.18
I’ve tied several different makes and sizes of micro SD, always with the same results.
I’ve reformated via PC and player, none of which seems to help.
-The player can’t read any of the files on the memory card, however the card shows up in windows media player as drive G: when you connect the player to the PC. You can play those files via media player.
- Occasionalt the message “There is no disk in the drive. Please insert a disk into drive\Device\Harddisk3\DR3” comes up.
I only really bought this player for the expandable SD card slot. Is there a solution, or so I return this to seller?
