I just got a sansa clip yesterday, and the volume was fine when I first turned it on. But then a couple hours later, I turned it on again, and the volume even on the very lowest setting is really loud. I can’t figure out how to turn it down. Someone help me!
Make sure you have version 20 firmware installed.
should that have already been installed when I bought it? or should i take the thing back?
I followed the directions but my version is still 1.01.18 or something like that. Do I do it right? Here’s what I did.
Extract the file for the US
Save to a folder on my computer
Drag and drop file onto folder under “Internal Memory” on Sansa Clip
Disconnect Sansa Clip
Turn off power
Turn power back on
Verify under “System Info” which version it is
Here’s the difference:
Double click the Internal Memory to open it up (files will be visible, this is MTP mode).
As you drag and drop the m300a.bin file to this folder view, be sure it transfers there.
As you disconnect the Clip, “Firmware Upgrade in Progress” will display on the Clip, confirming that the process is complete.
Continue as you described, checking the loaded firmware version.
Yay!
Bob :smileyvery-happy:
it did transfer there, but when i unplug it, it doesn’t do anything.
what’s MSC mode?
ok i tried it in MSC mode, and it still didn’t work. Where exactly do you drag the clip01.01.20a folder?
never mind. I finally figured it out. Thanks for your help!
