Hi
So it would seem, that this is a common problem, and it is most likely caused by ID3 tags.
My problem is though, I can not get any of my computers to recognize the device.
I have tried: Holding the power button for more than 20 secs. It just resets and then comes back to the refresh media screen.
I am pretty sure that if I could manually format or delete everything, I would be able to start again. Is there a sequence of buttons I can press that will do a “Hard Reset”? Or is there a way I can force my computer to recognize the device?
Thanks
