I’ve had a Sansa Clip for nearly 3 months now and about a week ago, I noticed a strange “imprint” behind the screen. Every day, the screen got dimmer and imprint got clearer. I’m pretty sure it’s the sansa clip and monitor icon that appears when you connect the clip to the computer. Anyways, the screen is so dim I can barely see anything. Is there any way to fix this or is my player just about cashed out?
I’ve tried reset, I did the firmware updates as soon as I bought it (July 1, 2010). I only dropped it once while opening the box on the same day (packaging was ripped), but nothing happened to it.
If you bought it new, Sandisk products have a one-year warranty in the US. The warranty may be longer or shorter in other regions. You can call their support number (1-866-SANDISK in the US, I believe) and arrange for a replacement under warranty.
I actually live in Canada and I bought it from TigerDirect, which only has a one month warranty. I guess I’m out of luck. Would downgrading and upgrading help by any chance?
If it was new, it doesn’t matter if you bought it from TigerDirect, the manufacturer’s warranty still applies. If it’s refurbished/recertified, then you’re stuck with TD’s warranty.
Reinstalling the firmware may or may not help (honestly, it probably won’t), but it can’t hurt to try.
No luck with the update. Thing is, the battery sign appears fine. I think there’s a bunch of logos overlapping each other in the background continiously, dimming the screen really bad. Anyone know why?
Part of me assumes that this is a hardware malfunction. And part of me is curious as to what would happen if you Rockboxed your player (although I only would try that as a last ditch attempt–it could make matters worse, or the player, even, nonfunctional).
You might want to leave it charging overnight–sometimes that seems to fix issues. Also, just leaving the player alone a few days has caused resurrections.
You don’t really have much to lose, right? There are special plastic “tools” designed to spread apart casings if you want to try and find some. That would be better then scarring up the case using a small flat screwdriver to take it apart this guy suggests.
