Sansa Clip + Rhapsody
I attempted to charge and sync my Clip through Rhapsody.  I received a message from Rhapsody stating that “Your device is not operating properly. To fix this problem, you need to reformat the device.”
I have (1) Reformatted the Clip; (2) Reset to factory settings; and (3) Downloaded and installed the latest firmware (V01.02.18A).
I still receive the same Rhapsody message.
I have checked “My Computer” and the Clip appears under “Portable Devices”. Right clicking on the Sansa icon tells me the device is working properly.
I have checked Device Manager and find that the device is working properly.
I am able to transfer a song to the Clip using Windows Media Player.
Is there a compatibility issue between Sansa and Rhapsody?
My Rhapsody version is 6.17.15.0.
Thanks!
Did you re-authorize the device with Rhapsody?
