my clip just stopped powering up. It will turn on when hooked to the computer for charging and editing but as soon as I unplug the cord it wont turn back on. Ive tried doing the 20 second reset thing a couple times and has not worked. It made it through 11 months of my deployment here in Iraq but it might not make it on the flight home if it doesnt start up again. does anyone have any suggestions? (besides quit listening to music when fighting bad guys)
Has all the symptoms of the dreaded detached-battery-lead problem, in which case you’re hosed unless you want to try opening it up and soldering the lead back on.
You can’t get to the Clip’s menu at all, even when connected to your computer, right?
I just noticed that I’m having the same problems with my Sansa Clip. Initially I thought it was because I was running out of juice, so I plugged it into the car charger for my GPS (I’ve done it before with success). Then I noticed that whenever I unplugged my Sansa, it died, just like others have described.
I was soooo close to doing some surgery on my Sansa…but it still works when plugged into the car charger…so I guess I’ll deal with the lack of portability of it. LOL Good thing I drive a lot for my job.
Can I ask, where did get your Clip, and for how long have you had it?
And here i thought i was the only one with this problem. I’m to scared to attempt to open mine up. So far the only solution i’ve heard is detatched battery lead whatchamaycallit. Well that’s not telling me how to get it fixed. I could try to get a new one but the one I got was a gift.
