Hi there
When I first got my clip the audible books I downloaded displayed with multiple tracks within each file which was great for navigating around from chapter to chapter. However, for some reason I can’t work out, this no longer happens - the tracks show as 1/1 rather than 1/15 for a book divided into 15 tracks. It’s not a problem with the audio book files, as the same files that used to display with chapters don’t do it any more.
I wondered if it might be connected to a firmware update which I did at the time (from whatever it came with in the box to 2.1.32) - it coincided with the appearance of a sub-folder within audiobooks called “audibles”.
I’ve tried: updating firmware, initialising settings, reformatting, changing USB mode, changing sync software (audible manager/WMP/zune). Can’t see anything in the manual or forums on this issue so am at my wits’ end!
Can I revert to an earlier version of the firmware to see if this fixes it? Any better suggestions?
Jess
