I just installed Media Monkey to see if it could do such a task.
Unfortunately, I haven’t been able to figure out how to do it, if it does.
There is a “Convert Audio Format” under the MediaMonkey tools menu. But, I don’t know whether MM supports M4A (as a source format), and I don’t know whether you need to buy MM Gold to get the conversion tool.
Much gratitude!
Conversion in process…
very slooooow.
No need for the gold. The free version converts.
Hopefully this solves it. We’ll see in a couple hours, once the conversion completes.
Even so, is it not prudent to have my songs in Mp3 (the universal) format?
And I think the itunes program (for an antiquated shuffle) I originally had on my computer may have converted the songs to m4a format from the beginning.
I just always assumed they were mp3s. In one of my searches, I read itunes converts songs to m4a format by default?
If that is so, Rhapsody is not to blame.
Unfortunately, I removed itunes from my computer when I obtained the sansa clip since my shuffle had long since broken and been thrown away.
Last night I attemted to reinstall the itunes program, but it required the serial number from the back of the discarded player.
I know I could have just downladed it free online, but I resolved to get a new, more universal music management program. Hence, I have installed Media Monkey and am hoping for the best!
If you still had your Shuffle, MediaMonkey would have been able to sync it anyway.
Also, you probably want to allow your batch conversion to complete, but for the future … any background process (such as this) can be terminated in MediaMonkey by right-clicking on the status bar at the bottom and selecting “Terminate”.
Well, the conversion completed, I uploaded everything to the clip and discovered the conversion left the library with two copies of each song: one m4a and one mp3.
After juggling and deleting all those m4a files, I detached my clip, plugged in some headphones, crossed my fingers, and pressed the “it’s go time” button.
Houston, we have sounds!!!
I repeat, Houston, we have sounds!!!
Much gratitude to all you fine people for your assistance!!!
:robotvery-happy:
My Sansa clip is acting weird. It’s a 4-GB,top model–
I was listening to it,and all of a sudden,it stopped working. I tried to charge it (I let it sit for about an hour.) When I tried to turn it on,it still wouldn’t turn on. I held the power button down for 15 seconds as the guide stated…
And now,when I plug it in,my computer doesn’t even track it.
