Daughter got one for Christmas. I’ve been working for hours trying to get the thing to work. The computer initially shows the new hardware added - Sandisk. Then that quickly changes to new hardware added–USB Mass Storage Device. When I went to My Computer, it was not listed. In the Device Manager, it said that the device was not working.
I’ve downloaded the latest update and installed it. It said to connect the Clip and hit next. Nothing happened. I even copied the .bin file to the destination folder as someone else suggested. Guess what? No help still.
Any help will be greatly appreciated.
Message Edited by johnrandal on 12-25-2007 11:57 PM
It never connected so that I could use it. It just said in the bottom right that it had found the new hardware - then, in less than 15 seconds, it gave the other message. It never appeared in My Computer.
The clip itself shows that it is connected and charging.
BUT…
When you check My computer nothing is listed.
The device manager shows: This device cannot start. (Code 10)
Uninstall with rebooting did not work.
Updating through windows on line did not work.
Looking for the divice driver on Sandisk I could only find the firmware updater, which does not appear to be able to communicate with the clip at present.
Does everyone have Windows XP SP2 (or newer, e.g. Vista) AND Windows Media Player 10 (or newer, WMP11 is much less fickle)?
XP SP2 and WMP10 are the official minimum requirements, although you can put it permanently in MSC mode after the firmware update and use on any USB mass storage-compatible computer.
That said, it will NOT appear in My Computer as a Sansa Clip unless you have Windows XP SP2 or greater, AND Windows Media Player 10 or greater.
Once you have those two requirements met, try adding songs by going into the Sync portion of Windows Media Player.
Please refer to older posts on how to update firmware. There should be a sticky thread at the top of the forum on how to create playlists using something other than WMP10 or WMP11.
***Searching and looking at older posts can be very helpful. Many questions were answered after Thanksgiving, when Best Buy had a promotion and a lot of people bought their Clips. :-)
I know the frustration you peeps are going through. I got an SDMX11R clip for my girlfriend (I still use a walkman cassette player) for her to download her songs and mp3 books. Thinking driver installations were a no brainer this day and time, I proceeded to insert the “Worst Buy” installation disk…thinking the driver would just install. Guess what…It bounces me to their site and tells me I need an account to get “the maximum features on this unit activated”…Wait… this to install a driver?..I hate Worst Buy and only bought it there because someone gave me a gift card I needed to squander. I get the same load error in XP with Serivce Pack2…finds the device…but won’t show up in My Computer. There is an error in system/hardware/devices…showing the usb device didn’t load. Hey…maybe I just need to become a slave to BestBuy and buy their music…and the device will mysteriously work. Tried to get a driver straight from SanDisk…and the model isn’t even listed in their download page…no wonder XP won’t recognize it…heck, neither does SanDisk!!! Well I’m ready to return it and buy another brand and divorce SanDisk and Bestbuy. BTW…my cassettes work great without all this ■■■■.
Going through exactly the same issue as the original poster of this thread:
I plug the player
computer tells me “found new hardware - USB mass storage device”
sometimes goes as far as telling me it’s a Sandisk Clip
then nothing
then the usual “there was an issue, your device may not work properly”, and the device does not appear in My Computer
I have tried on 2 different PCs
one is Win 2000
the other is XP (not sure SP2 is installed though)
I have tried the firmware updater on both PCs, goes to the final stage of “Plug in the player then press finish and the updater will start automatically” - It doesn’t even blink
I have also tried to force the player into MSC mode (whatever that is) to do the firmware upgrade as this was suggested for users under the min specs.
some people have mentionned to go to “Settings\USB” on the player - I can’t find it on mine
as for the “hold button on + press the centre button while plugging in” method, I must be doing it wrong because nothing happens at all (I have tried with the player on or off, on both PCs, and nothing).
I have already resetted and reformatted the player as well, and looked at the letters that were assigned to the different drives on the PC. I am now out of options and losing my nerves. Can anyone help?
I have a plane to catch later today so I will be returning the player to the shop in about 1 hour unless someone is kind enough to help me out before then (bought the player at my parents’ but I live in a different country).
Well I’m downloading Windows Media player as we speak…but here’s my beef about all this…why does a software driver need all this to run, why is this stuff not in big bold letters on the instructions and lastly, why won’t it run “out of the box” with a simple driver install and a small loader program. This software driver should be included on the useless CD that WorstBuy sends…( and it should run in older versions). This is a simple read/write operation for uploading and downloading a file to this unit the same as a flashdrive. You should not need all the updates to get files to upload and download… We’re not installing AutoCad here.
This is not a problem with the Scandisk itself, but I’m not giving Worstbuy one more penny and that includes their useless download site that they say I have to set up an account with in order to " enable all the features on the scandisk". If I want to go to download.com and download FREE music so be it. This unit should be able to read and write any MP3 file fine and heck it should be able to do it in win98. It’s sad to see that the frustrated users must use this site to transfer information in order to help each other get this thing to work. If this many users, (and they sound knowledgable to me), are frustrated with this connection problem, then Sandisk needs to address it.
Also, Scandisk should provide a basic driver for the SDMX11 on their download site (and on the included CD) to get this thing going, this shouldn’t be a research project. If this thing doesnt’ load free files after all this I am head to Worstbuy to get my money back. Hey, it does sound great on the included demo song. That’s what I bought it for…to bad all this agony has to be spent accessing the unit and WHERE i have to get audio, since it seems to be a great sounding unit for the price.
It seems that you will need to install the Rhapsody software first in order to get the unit to be recognized on the PC. You will NOT need to sign up for a Rhapsody account (unless you wish to). Make sure you have Internet access while you are installing as the Rhapsody installer will want to go out and do updates.
One note: our version of Clip is a BestBuy exclusive and may be the reason why I had to install Rhapsody. The Rhapsody software takes you to the BestBuy Digital Music Store. My son received a Sansa Shaker for Christmas and that guy was plug and play - no issues at all.
Once installed the Sansa Clip will become available as a drive under My Computer. You can use the Rhapsody utility to manage your music, pics, etc… or just drag and drop within Windows. The Rhapsody utility is not too bad. It will allow you to rip directly to MP3 from your CD’s. I think Windows Media Player will only rip to WMA, but I can’t swear by it. Also, as others have mentioned, make sure you meet the minimum requirements with Win XP SP2 and Media Player 11.
When your install is complete you can download the updater from the Sansa website and allow the updater to perform a firmware upgrade on the unit.
There may be an easier way, but this has worked pretty well for me.
Unfortunately I don’t have any more time to waste on this product. I have bought it in France where I have never heard about Rhapsody or BestBuy so I am not going to look into what these are. I am simply going to return the player to the store where I bought it and get a refund - I’m not even sure I want to try an exchange.
From a commercial point of view, I find it absurd for a brand like Sandisk to sell half-finished products that won’t work on a PC that’s more than 1 year old and not provide the correct support (why, but why isn’t there a driver available online like almost everyone else does?). I have to say I am gutted as it looked like a great little player - However, I will be writing a negative review of this product on my retailer’s website (as this is what unhappy customers do).
Well after the windows media player 11 install that it took two hours to download on dialup I’m happy to say that I’m playing download.com songs with pride. And for the BestBuy CD…my dog’s chewing on it as a frisbee. It may be rigged to run in versions other than XP/SP2 and Windows Media Player 11, but good luck and you can probably use the notes on your engineering doctoral thesis if you get it figured out. It’s been a long arduous task…but it does sound good…and thanks to all you hard working, people who made this mp3 communication interface project a success with your determined efforts!!!
no miikerman, I don’t think its too much to ask that a driver thats supported by multiple systems included on an install disk, including older systems, as many people arent technically adept, and don’t want microsux auto installing updates on their machines when they are working fine at present, including me. I don’t need to pay hundreds for a new OS for a device that cost me 40 bucks…I don’t have to do it for other types of drives and other devices such as printer so why should I need it for Sansa…every looked for a printer drive on HP’s website? Think they require sp2 and XP for everything…NO!!!.
As for the Worstbuy Crapsody software… I don’t need it, and I don’t need WorstBuy…I’m downloading great music and its legal and FREE on other sites. And I salute the guy who got his working in 98…media player11 is a dog.
I can’t get my computer to recongize my device. First I tried the manual it didn’t help at all. Then I downloaded the Sansa Firmware Updater. Still nothing worked. Then I went into my settings on my device and I Formatted it and still have no luck. If anyone has any tips please reply back. I’m not exactly a computer person so explain things to me step by step.
On my Sansa Clip, it didn’t even have a “USB Mode” option on the settings menu (needed to switch it to MSC mode to make it recognized as a USB ‘drive’ in Windows Explorer). After fighting with this for a bit, I determined that I needed a firmware update.
To do a firmware update to the Sansa Clip, go to this URL:
Download the Sansa firmware updater and install it.
Reconnect your Sansa Clip–the Sansa Updater will detect it, find the latest firmware–you need to check the box (says something like ‘download firmware update’) on the popup that displays, and the Sansa Updater will download it and install it.
Once the new firmware has been installed, disconnect your Sansa Clip and let it finish processing (a minute or two)
When you reconnect it, go to the Settings menu, select USB Mode, select MSC.
Disconnect and then reconnect your Sansa Clip, at which point XP will see it as a USB flash drive and assign a drive letter.
Hello people.
I am running a rebuilt computer with Windows XP which will not validate and thus, will not accept the sp2 update.
I have read and followed the instructions provided regarding downloading the .zip file, unzipping it, and installing it on the player.
I am still having trouble with the player not recognizing the uploaded songs.
After tonight’s battle with my sansa, I think I have discovered something which may or may not be of interest.
Last week, when I originally attempted to synchronize my library with my sansa, I ended up installing that Rhapsody program on my computer. I’m pretty sure when that happened, it reformatted all my mp3s to m4a -for some unknown reason.
Is this a problem? And how does one correct the malformatted extensions without converting each individual track?
Still, from the beginning, my computer has recognized the Sansa player and seems to upload songs to it. But it tricks me, so that when I go to play something, it says I have nothing.
It makes me sad.
So, anyone want to tackle this one?
Please?
What once was a smooth holiday move, has turned into quite the frustrating endeavor.
:robotsad:
.m4a is an audio-only MP4 file, which the Clip will not support. Not sure how/why Rhapsody converted your MP3 files, but you’ll need to convert them back.
I have had Windows Media player 10 intalled on my computer from the beginning.
And, how does one convert them back to mp3 form in bulk?
I just installed Media Monkey to see if it could do such a task.
Unfortunately, I haven’t been able to figure out how to do it, if it does.
I also tried reinstalling Rhapsody to see if there was a preference setting I missed in the original installation.
I found nothing so I removed it again.
Oh yah…
And I don’t purchase and download protected songs off the internet.
I have way too many actual CDs to ever do such a thing.
So, DRMed music is not an issue.
