I updated my Clip from V02.01.32F to V02.01.35F when I had a problem with losing files (now sorted using MSC).
Unfortunately the volume firmware control disappeared (now sorted using ‘Rest of World’ setting) and the balance between the earpieces changed.
Has anyone got the bin file of V02.01.32F that I can have so that the firmware upgrade can be reversed (if it’s possible!!)?
Thank you.
