sansa clip does not power on
I first tried to connect the clip to my pc but it did not show up in the “my computer” window. The clip screen used to show as “connected”.
After several attempts,  the clip stopped connecting (screen does not show “connected”) and remained in the play mode.
Now the clip does not power up when usb cable is plugged in nor does it power up with the button.
Any solution to fix the above problem will be appreciated???
Do you have windows media player 10 or newer installed?  Have you tried connecting it on another computer?
I also have this same problem. I have 2 clips 1 works fine ! will not turn on or connect to computer.Anybody else have this problem.I suspect I will have to call sansa.
Try holding the power switch slider in the UP position for >15 seconds - this resets the Clip
I was having the same problem and your reset trick worked great thanks!
yippee, that worked.  I plugged it in to the ubs, held up for 15 seconds and that worked.   I hope this doesn’t become an ongoing problem.    I have another older clip and have never had that problem.
