I need help please. I have two players. One is a Sansa Fuse+ and the other is a Sansa clip+ (4gb). I can put a slot radio card in my fuse and can see all 7 channels of music, but when I put the slot radio card into the clip+ it only shows 2 of 7 channels. Does anyone know why this does not show all 7 channels? It does not say anything about it not being able to handle the radio card it even states how well it would work with it.
Is the firmware up-to-date on the Clip+?
Yes and just to make sure I went to update it today and there was no update available
Well, the screen is much smaller on the Clip+ than on the Fuze; are you pressing the bottom button to scroll down in order to see the other channels?
Call tech support 866-7263475
http://forums.sandisk.com/t5/Clip-Clip/8GB-Clip-and-slotRadio-cards-playlists/td-p/219014
I read all the posts from those posting on this same problem and seems there is no solution to the problem except to ■■■■ up the cost of it, toss it out and buy another brand that works a bit better. Thanks for the attempt to help anyways…Oh and btw…not going to call and go throw the hassle…they didn’t even bother to reply to my email from a week ago either…
