Sansa Clip 8gb / 24 bit audio files
Just got a Clip & am setting up dBpoweramp. Does my Clip play 24 bit audio files?
I cant say for sure because Im not sure what you mean exactly. Are we talking about 24-bit in terms of quality? I would venture a guess and say it will play them if you use a compatable file type
Hey SG. Thanks for getting back. I am talking about 24 bit sound quality. I’m setting up dBpoweramp for ripping & considering using the HDCD DSP so that any HDCDs would be ripped in 24 bit instead of 16 bit audio. No need though if my Clip won’t play 24 bit. Just occured to me, though, that I might be able to archive HDCDs in 24 bit & convert from 24 bit to 16 bit for my Clip. I’m assuming that Windows Media Player will play 24 bit files. Any way, can’t find this info anywhere in specs for Clip & tried calling Tech Support too late last night so thought I’d get out here & ask my first question. Look forward to hearing back.
Another question about Clip DSP support. Does it support ReplayGain? Is there a resource that lists detailed specs like this?
I’m new to this so, please, bear with me! My understanding of ReplayGain is that the value is written into the file so any compatible player can then read and use it. Sounds like MP3Gain. What’s the difference between the two?
Very helpful. The fog is beginning to lift! If I did use ReplayGain while rippng, would my Clip be able to play the files any way without the effect? What is ReplayGain (apply)? Really appreciate your help …
This is really helpful. Thanks!
Another question: Does the Clip support gapless playback? Getting gaps at the track transitions on live cds converted to FLAC for my Clip. Just started looking onto this. Seems it could be a conversion issue and/or a playback issue. Your thoughts?
Message Edited by JimManko on 09-11-2009 12:19 AM
