just got clip, transferred audiobook, it’s stored in music, not audiobooks
It really depends where the audiobooks came from.
The Sansa doesn’t know what’s in an mp3 file unless it is placed in the right folder (Audiobooks) or tagged as an audiobook (in the ID3 tags, the electronic labels in the files). Otherwise the Sansa assumes all mp3 files are music. Wouldn’t you?
If your audiobook is from a library, you may need to set the Sansa to MTP mode and transfer it from the library’s media player/console (like Overdrive) so that its hidden digital-rights codes are also transferred.
Or if you got the audiobook elsewhere, it may be sloppily tagged. You could use tagging software like mp3tag (free) to make sure the Genre tag reads Audiobooks.
Or, as suggested above, place it manually into the Audiobooks folder.
