I have two black sansa clip 1.0 GB. I have the same problem with both of them. If I connect them to the computer or a wall charger they turn on and work properly. When they are disconnected I can’t even turn them on. I have downloaded updated firmware and I don’t know what else to do.
You might try a reset hold the on off switch up for 15-20 seconds and see if that does the trick.
Also make sure the clip is charged.
Lee
Message Edited by leemann on 06-28-2009 06:35 PM
Have they fallen recently? Sounds like the lead to the battery has come loose (covered by the 1-year warranty).
You didn’t by any chance get your Clips from a recent woot.com sale, did you? I’m having the same problem.
