My sansa clip wont turn on, unless it’s plugged into my computer, it will show that it’s charging but when I unplug it it wont turn on. I’ve tried resetting it but that didn’t work, help.
i have the same problem. i can get it work while hooked up on the USB but when i remove it, it says “disconnected” and does nothing. help
If it’s the original Clip (and not the Clip+), there were many who had defective solder joints on the leads to the battery. It can be fixed, but you have to take the casing apart, which can be tricky to do w/o damaging it. Check the anythingbutipod forums; there’s a post/tutorial complete with pictures on how to do it.
