Sansa c250 player
The only way that my mp3 player will work is if I plug it in.  It will work when I plug it into the charger? How do I get it working again.
doesnt make much sense.
You cant turn it on when its not plugged in? You might want to call support; to walk you through the steps. 866.SanDisk
so does it work only when it is plugged in to the computer or only when it is disconnected?
if it only works when it is plugged in it may be a battery issue.
