Kay,How do I know my MP3 is charging?Cause I let it charge for a weekend and it did NOTHING!Whats up with that?
when your connected to the computer, it should say connected on the screen. The battery shows a lightning bolt or somehting if im not mistaken.
can you turn it on and see how much battery is left?
anytime your connected via the cable, it should be charging.
Are you connecting the sansa to an unpowered hub? If so, connect it directly to the computer or use a powered hub.
Good advice. I never even thougt of that. I don’t have the problem, but that’s good to know.
