My Sansa 280 locked up on me, I just get the startup screen that says “SanDisk” fading in and out over and over. Tried to do the resets, nothing, held the power button for a while to shut if off. Used the Hold and Record proceedure while connecting to the computer to get into Recover Mode and the computer sees it as 16 MB-Format, with a text file showing:
■■■■. Did it, looked as if it worked, but after unplugging it just keeps cycling between the SanDisk boot screen and Refresh Database. I renamed the file to PP5022.mi4 as instructed and copied it to the drive. Tried it twice. Maybe I’ll try one of the other files.
**bleep**, failed again. It restarted properly, but didn’t show any of my files. Plugged it in, it loaded properly, and the files were all there. I deleted a few, added some new ones, unplugged, and it went back into cycling between boot and refresh. Maybe when I’m connected after the mi4 reboot I should just format?
Tried it again, didn’t seem to work, plugged it back into the computer, went into refresh mode, which is weird since it normally does that when unplugging it, but it showed up properly in the computer when done, unplugged it, refreshed again, as normal, and now I’m using it! Don’t know if it’s stable or not but it’s working for now.
Now that you have it working again, you should be able to upgrade back to the newest firmware version. According to your first post, this is the version (01.02.24a) you had to begin with.
I went for the update through the Sansa Updater, seems to be working fine. Yay. I’ve had this thing for so long and still love it, wasn’t looking forward to getting something different.
Great! Now I’d recommend un-installing the Updater. There won’t be any more updates for this model, and everytime you plug into your computer it will want to ‘phone home’ looking for one. It can be quite a nag, besides being a resource hog on your computer.
If you ever need to re-install the firmware (which the Updater won’t do, it only updates), you can simply follow the manual installation instructions in the firmware posts here on the forum. It’s quick and easy.
