Sandisksecureaccess already running
Hi, i have 1tb extreme pro. I am
Using on macos monterey. Suddenly, i am gettin sandisksecureaccess already running message when i try to open. I checked relative topics. Do you have any advice? Thanks
This usually happens when SecureAccess didn’t close properly or is still running in the background. Try restarting your Mac, then open the Activity Monitor, search for any process related to “SanDiskSecureAccess,” and force quit it if it’s still running. After that, try opening the app again. Also, make sure you’re using the latest version of SecureAccess that’s compatible with macOS Monterey. If the issue continues, consider reinstalling the software.
