Hi guys,
I would be so grateful if anyone out there can help me, or shed any light on this.
I used the vault which I installed on my Ultra Fit 64GB drive, and I filled the vault completely. Everything was fine, and I could access files, but after the 3rd of using it, it said “SanDiskSecureAcess is Already Running.”
I have tried it on about 5 different laptops and PC’s but it just comes up with the same message, even if its the first time that I’m using that machine.
Very silly of me, but I don’t have a back up of these files anywhere else
Does anyone have any idea what the issue could be?
I can see all of the encrypted in the settings folder, is there anything I can do with them to get my data back? The vault software wont open at all, no matter what I do!
Thank you.
