I bought a SanDisk Ultra Fit USB 3.1 flash drive a few months ago, and I’ve been having ongoing issues with it. Hoping someone here has experienced this and found a fix.
When I plug the drive into my computer and start transferring files, it works for a few minutes but then:
The drive becomes extremely hot to the touch – almost burning hot
It suddenly disconnected and disappeared from File Explorer
The transfer fails and I have to unplug and reconnect it
Sometimes Windows gives an error saying “USB Device Not Recognized”
This tends to happen particularly when transferring large files or when the hard drive is in continuous use for more than 10–15 minutes. It sometimes works fine when transferring smaller files, but the hard drive still gets very hot.
Is this level of heat normal for this drive? It seems way too hot.
Any advice would be really appreciated. Thanks!
