Sandisk SSD ULTRA PLUS Firmware udate went wrong....
I just bought this SSD drive (256gb Version).
Installed windows and after it the Toolkit.The tool said an firmware ubdate was available.
Made the USB stick and after that rebooted and firmware update was done. No errors here.
Problem is now that BIOS will not reconize anymore the SSD???
Best Regards
Frank
If the BIOS is not recognizing the SSD there really is not anything you can do to fix it. It will need to be replaced. Contact sandisk support for warranty claim.
