hi,
I got SanDisk Extreme USB 32gb drive and i’m trying to use Sandisk SecureAccess software. when i run the software it says
“Please run sandisk secureAccess from a sandisk external device”
My O/S is windows 8.
hi,
You have to run it from the flash drive, not the computer.
i tried to run it from the flash driver but it didnt work
Does Windows 8 support running apps in Compatibility mode? If so see if SecureAccess runs as Windows 7 mode.
Try this, right click on the icon saved in the flash drive and click properties. Then compatibility mode. Then look for options, I mean do a trial and error. But make sure to remember the original set up.
