What happens if you Safely Remove the USB drive and reboot your pc and then try to access your files?
Hi
I have always safely removed the scan disk. I have also tried safe removal and rebooting the pc with no success
Check your Recycle Bin to see if the file got accidently deleted. If not there try one of the free undelete apps posted here to see it’s still on the drive.
If that doesn’t help you may have to reinstall the SecureAccess app.
Hi guys
Just bought loads of 16GB Dial drives and had the err=1 message: Failure reading the filesystems file
After going nuts for the past hour, then reading everyone’s comments on here, I decided to try removing all SanDisk software off the drive (temporarily, to my hard drive) EXCEPT SanDiskSecureAccessV3_win - TA-DAAAA!! when I opened the program again, everything worked like a dream and I got the ‘Secure Access - Create a Password’ dialog box, as described on the installation instructions included with the drive. I AM NOW LOOKING AT THE MAIN INTERFACE AFTER SPENDING SECONDS SETTING UP SECURE ACCESS…FINALLY!
Renaming the .exe. file didn’t work for me, by the way. Neither did reformatting the drive.
I’m about to transfer the other files back to the Dial drive. With a big grin on my face :D
" I decided to try removing all SanDisk software off the drive (temporarily, to my hard drive) EXCEPT SanDiskSecureAccessV3_win "
"Neither did reformatting the drive. "
Pretty sure reformatting the drive removed SanDiskSecureAccessV3_win.
Hopefully the other files you plan on transferring back aren’t .dat files.
Hi Ed
It looks like you either didn’t understand my message or I wasn’t clear enough - so for the sake of clarity and other people’s sanity (!)…
I had already tried to rename the v.2 .exe but it made no difference when I double-clicked on it - I still got the error message. So I then tried cutting ALL the files off the Dial (after I’d reversed the file name change), pasting them to my computer desktop, reformatting the Dial, then pasting the files back onto the Dial and trying again with the .exe file but that didn’t work either.
In the end, the only thing that worked was deleting Secure Access v.2, downloading v.3 onto the Dial, leaving that ON the Dial but cutting the other files and pasting them onto my computer desktop…leaving only the v.3 on the Dial. I then double-clicked the v.3 .exe and hey presto…seconds later everything was working. I then pasted the files back onto the Dial from my computer desktop.
I’m guessing it doesn’t matter whether or not the files were .dat files because it worked.
Thank you for the clarification bigblueamazon and for the happy ending. ![]()
you should have call to there customer care number where you will get help for sure. If you dont know there Toll Free Number than please visit.
Customer Online 24/7 Information Support
I tired it … still it wound not open .!!
Thank you Deponia as I had the same error and your suggestion fixed it in one go
I have been using the Sandisch Secure Access V3 for a few years now. Most of the time it works fine but around 1 in 10 times, when I click to open the file it just seems to freeze with this on screen (see attached picture). I have tried renaming the .exe file, closing it and trying again but the only thing that seems to work is restarting my PC. Spotify Vidmate Apk Apk mod
This problem is very common for all.I also have face same,so i contact AOL customer support for help,they provide me the best service.If you need you can also go there for help.
Deponia,
Thank you for that link address and the instructions. It worked like a charm. I’m so happy for people like you available online to help people like me!
Leiunitus
All you have to do is download the newest version.
Hi, are you still interested in recovering your data or you got rid of your Vault and/or USB Stick?
I can help you save it if you are still interested in recovering your data.
Downloading new 3.02, deleting the older version, and replacing the new version on the SSD DID NOT solve the problem.
Problem remains: V3, V3.01, V3.02 ALL have the OK button GRAYED OUT no matter what I do.
In Control Panel I have no application installed with the name SanDiskSecureAccessV3_win.exe. So there’s no way to uninstall it in Windows! Regardless, the application ONLY runs on SanDisk USB Drive!
This is a DEFINITE MAJOR PROBLEM in V3.02!!! (much bigger than a bug).
I can’t store files securely on this Drive!!!
Why does SanDiskSecureAccessV3_win.exe need to access the Internet every time it starts??? That defeats the purpose of a local solution when I’m not connected to the Internet. I’m beginning to hate SanDisk. What a piece of ■■■■!
That did NOT work for me.
What happens when you remove the check mark in front of the red letters? Use numeric and alpha numeric characters
And what the heck are “alpha numeric characters”??
The Internet access requirement is an option that can be turned off, once you sign on.
Shocking that this product is out there, many don’t want this encryption in the first place. So ■■■■ poor. Cannot get it off even with disc management.
Wah -Wah identical situation. Should be asked if you want it.
If you don’t want it, don’t use it, and DELETE the files and folders associated with it. Not a big deal imho.
