hi there
I am having problems with sandisk i100 16gb … windows is always giving the same error for it, … slow boot and system hangs
i don’t know if the ssd gone bad or if it’s a software problem. any help would be appreciated Thanks.
for now i removed express cache and disable the disk, so i can work,
SAMSUNG 530U3B
WINDOWS 8 64 | WINDOWS 8.1 64 (tried to updated to see if would fix the problem.)
Device manager show the disk with the following drivers
disk.sys ehstorclass.sys partmgr.sys
TRIED TO INSTALL SEVERAL VERSIONS OF THE EXPRESS CACHE. (from samsung site , from sandisk site)
with and withou intel rapid storage.
Error in event viewer. (always the same error)
Windows 8
The IO operation at logical block address for Disk 1 was retried
Windows 8.1
The IO operation at logical block address \Device\00000035 (name PDO: ) was retried
You can’t perform any alterations to the disk, tried with diskpart and disk manager gives the error:
VDS fails to write boot code on a disk during clean operation. Error code: 8007045D@02070008
