SanDisk Extreme Portable SSD Password Change
I want to change the password of my SanDisk Extreme Portable SSD 500GB, but I don’t know how. I would appreciate it if you could kindly guide me through the process.
Thank You.
(Get Support for Your SSDs and Flash Products | SanDisk)
The password process will be different depending on the software being used. e.g. SanDisk Security or Private Access.
(Contact Support | SanDisk)
Thank you for the reply, yes I did check out the SanDisk Security and found out from there I can change the password, and it works.
