SanDisk Extreme Portable 2TB - Forgot password
I have set Sandisk drive software to remember my password on my laptop and i forgot the password that i had set earlier on the drive. I can access the data as every time i want to use it its auto unlocked. Now i am planning to change the laptop i need ur assistance to reveal or read the saved password on my laptop.
@MoeTag
(Get Support for Your SSDs and Flash Products | SanDisk)
Try this one.
(Contact Support | SanDisk)
Hi @MoeTag
Unfortunately, the saved password in the SanDisk software is encrypted and cannot be revealed directly. To avoid losing access to your drive, you can:
  1. Change the Password: Use the SanDisk software on your current laptop to change the password to one you can remember before switching devices.
  2. Disable Password Protection: If you no longer need the encryption, you can remove the password entirely from the drive.
    Do let me know if you need further help.
