Sandisk Extreme on Marvel9128 (Asus Sabertooth X58)
I need serious help…when i first connected the Extreme 120 it worked like a charm>installed windows 7> Asus Drivers> dead…no logging in Windows!!
Then the Bios(and the Windows 7) couldnt recognize the SSD as a HDD device (it sets a superspeed mode and ain’t working), when i am trying another HDD on the SATA3 (same port) it works perfect!
When i am attaching the Extreme SSD on SATA 2( intel controller) it also works pefect…but aint working on SATA 3 port(Marvel 9128)
any suggestion?? I have updated the SSD to the latest firmware (201)…same problem
I have also tried 3 different Bios for my MOBO…
I think it’s an SSD problem…what should i do?
Is there any way to RESET the SSD to his default state?
thanks a lot!!
You might try posting a question in the Forum at www.thessdreview.com ;
there is an active thread on the SanDisk Extreme 120GB SSD here:
http://thessdreview.com/Forums/ssd-discussion/2193.htm
The folks I’ve encountered there seem pretty knowledgeable.
MRFS
thanks a lot!
IS there please any way to rest the SSD to his factory settings ( clean him from anything installed?)
nice. :blush:
