I’ve already done that. Didn’t make the slightest bit of difference.
When I plug my USB 3.0 external hard drive into the USB 3.0 port the SanDisk Extreme was in it works perfectly. Take it out and put the SanDisk back in … nothing.
Clearly the problem is with the SanDisk Extreme and it’s USB 3.0 compatability. (As I mentioned above, when it is plugged into a USB 2.0 port it works just fine).
Saw this thread from January. My extreme 32GB was working fine yesterday. This morning it’s not recognized as a USB 3.0 device on 3 different (nearly identical) PC’s. Nothing has changed so I’m mystified. Works fine as a USB 2.0 drive.
The original poster never updated this thread, so I don’t know how – or if – he solved his problem.
I have this same problem with my extreme 32Gb and although its not really a fix, I have found that pulling it out of the socket slightly seems to make it work .
Therefore think this is probably a design fault with the connector, although it does seem that once it’s recognised, it can be pushed in properly again.
Thanks for that tip. That did the trick for me. I remove it completely then push it in very slowly, when I see the light light up, I hear the windows tone, then my sandisk is recognized. Then I can push it in all the way and it will work until I unplug it. Definitely sounds like a design issue or hardware flaw on my usb drive
Same issue here. 32GB SanDISK Ultra. Not recognized in laptop nor PC. It used to work for a while.
By the way. Both USB controllers are no Windows ‘default’ or anything of that kind. Hardly any USB 3 ports are. The older Sandisk, don’t know the type, it’s as big as my thumbs top, works flawlessly and always has.
What’s up next? RMA? Wouldn’t look good if it isn’t I guess. Anyone?
Yes indeed, when the sandisk stick is inserted completely inside USB 3 Port (works fine to USB 2 ports) is not recognized by any windows and also not even from bios of any computer generally when you want to boot from the USB stick to install or run anything.
But is detected and works fine when is not completely inserted inside.
I suppose too is a design mistake.
I have a multiple 64GB sandisk ultra USBs just want to confirm that Inserting the USB slowly into the a 3.0 port until it connects works perfectly thanks and pushing it fully in disconnects it again…
Hard to believe this kind of design flaw made its way into full manufacturing…
Oh no, I understand how annoying it can be to have your SanDisk Extreme not recognize a USB 3.0 port, particularly if you need to access your files quickly. It occurs more frequently than you might imagine, so don’t worry. You can try using a dependable data recovery tool like BLRData Recovery Tool if the drive still doesn’t appear, even though sometimes it’s just a driver or connection problem. It assists you in safely scanning and recovering files without requiring any difficult steps. Consider it a safeguard for your valuable information.
