I needed more memory so I got a 4 gig Micro SD card It fits in fine but the player memory doesn’t change. I even tried to load the card on my computer. It loaded fine but when I put It in my player It is not there Do I need something elece?
I don’t have a manual either. would be very thankfull for any insight.
If you have a v1 player, you cannot use 4GB microsd cards in the Sandisk firmware. You can either buy a newer player, or install rockbox on the device (rockbox includes a driver for larger microsd cards).
Thanks for the info . My player is Version 01.02.18A . Wear would I find Rockbox.
I downloaded Rockbox but don’t know what to do with it looks like an empty folder . I not very savy .
Definitely easiest to go with the Rockbox Utility (installer). You’ll also want to glance over the manual . . . it shouldn’t take too long; it’s only 220 pages.
