if i plug my SanDisk Cruzer Micro USB flash drive to the PC and start LaunchU3.exe error message 1001 occurs,
i tested this on four totally different physical PCs and one VM, with Windows XP and Windows 7 32Bit and 64Bit. After the error message occurs, the U3 CD Drive is empty till new Stick Plugin.
Launchpad version 1.6.1.2
The U3 Launchpad password feature is enabled on the stick, so the Launchpad Update doesn’t work.
yes i tried 4 pcs with different Operating Systems and different Software Installation nothing was the same, no antivirus or CD Burning Software… I rote the kb article about software incompatibility issues with the U3 device but in this case it wasn’t helpful
