I can not format or quick format my flash drive. If I try to open it Windows says it can’t be opened and aks if I want to format. If I say yes, Windows tells me it can’t complete the format. In Disk Manager it says that the drive has a RAW format and Properties says that it has 0 bytes used and 0 bytes free. I can’t format or partition through Disk Manager.
its a bad drive and will need to be replaced. i would suggest contacting sandisk support
I CAN NOT FORMAT THE FLASHI
Try this to software to format your cruzer: http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
If still cant be formatted, contact the tech support line.
It would help if you give us more details. Are you getting any error message? How are you trying to format the drive? what’s your OS?
Another good question would be why are you trying to format it?
just dualboot ubuntu by installing wubi installer from Ubuntu. Then just try to format the drive from there! (From ubuntu).
i hope this helped!
yar this doesnt work plz tell me another solution for my 4 gb sandisk memory card…on nisu_7488@yahoo.in
SanDisk Cruzer 4GB Format ını istiyorum.tşkkrlr
Huh???
hai there… i have a problem with my SanDisk pendrive,i can not format the pen drive.It says “windows can not complete the format”. later i figured its “write protected”… i want the data’s to be deleted from my pen drive and i can not use it properly that’s why i want to format the pendrive… Is there any possible way to make my pen drive work properly?? pls HELP ME!.. it was actually a gift from a friend and i can not get a new one.it really means to me alot…kindly HELP!!
i tried formatting from DISK MANAGEMENT
i tried formatting from Ubuntu
i tried this hp tool which was suggested in this forum
nothing worked pls kindly HELP ME
hai there… i have a problem with my SanDisk pendrive,while formatting my pen drive.It says “windows can not complete the format”. later i figured its “write protected”… i want the data’s to be deleted from my pen drive and i can not use it properly that’s why i want to format the pendrive… Is there any possible way to make my pen drive work properly?? pls HELP ME!.. it was actually a gift from a friend and i can not get a new one.it really means to me alot…kindly HELP!!
Tell your friend “thank you, it means a lot to me”, put it in a drawer and forget about it. It’s broken, which is probably why your friend gave it to you,
hello sir please my 4 gb pen dirver format
It is FAT32.
RETURN IT.
Either to where you bought it or to SanDisk.
