I used to two or three sandisk usb flash drives cruzers I think, they all had included upon purchase, in the case, a nice branded sandisk neck lanyard.
Only one of these remains in my posession now, the others lost or misplaced over time.
Today I purchased a new 16 gb sandisk usb flash drive, and low and behold, it has a lanyard port/clip area but no actual neck lanyard included, and I am considering returning it due to this fact and change in design.
The drive itself is too bubby shaped, I like the old rectangular style, with defined edges.
Anyways, whats the deal here and why cant I find any sandisk brand lanyards anymore?
Are there any sandisk products that still include these neck lanyards? or accessories packs that you can buy them in?
There used to be like 3 or 5 pack neck lanyards of sandisk brand on the shelves at staples and etc., now I see none.
I bought a 16 gig flash drive from Amazon, and I didn’t get th lanyard either. (It was the rounded rectangular shape, though.) I sent them a letter and got this reply:
“(Ryan Kullu) 06/09/2010 05:14 PM
Thanks for emailing SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product.
Please be aware that the lanyards are not included as these may be purchased as separate accessories. You may find them from any local retailers or online stores.
Please refer to your My SanDisk at http://kb.sandisk.com anytime to see all of your incident history and product registration information. You can log in using your email address as your login and the password that you created.
Also, you can visit http://kb.sandisk.com, our online keyword searchable Knowledgebase, to easily find answers to your Technical Support and Customer Service questions for all of SanDisk’s products. Simply enter your search terms and our Knowledgebase will search an extensive database of commonly asked questions as well as our online forums at http://www.sandisk.com/sandisk-support/forums to provide you with the most complete answers possible.
Best regards,
Ryan K.
SanDisk Technical Support”
