i tried rockbox since someone pointed that i MIGHT be a way to recover lost tracks on a external sd card , i lost half the tracks cause the player couldnt read them all of the sudden and screwed up the folders a bit
so besided it wasnt solved i have some issues now :
can i get back to normal firmware btw ?
there are no more MTP or MSC options , are those not in the rockbox settings ?
navigating is a bit confusing- eg how can you get the player to start playback GLOBALLY all tracks from internal + external (sd card) in one go- meaning if you start one track in shuffle mode that the player generates a shuffle playlist with ALL FILES not just of the current subfolder. with the normal firmware that was not a problem but now with the odd navigation menus …
its too loud, it ranges from -80 to +6 db in volumelevel, which would be the highest volumelevel in the NORMAL FIRMWARE mode ? i dont know but i was getting a headache quit fast
plus i wanted to format and retry in msc mode altogether relaunch all… since i cannot find msc anymore, can i just format the drive in windows ?
another eg : how can you generate a playlist of all the tracks on the external memory /sdcard
INTERESTING
does that lead to complication if i use BOTH firmwares? i mean sometimes the rockbox sometimes the “default”
hm if i not hold left while booting now appears : LOADING FIRMWARE FILE NOT FOUND and nothing happens
does this happen once you “hold left” while booting or is it somehow corrupted ? how can i get back to normal?
is it ok to use both firmwares when using the player?
(cause it seems i cannot install the normal firmware anymore once installed is installed. at least if i try manually and with sansa updater i get no change)
is there a manual for rockbox ? especially for database ? since it looks like im gonna have to use this … to get a grip
You should have looked at it before you installed.…
http://www.rockbox.org/manual.shtml
Make that _ studied _ it!
That means the .rockbox folder is missing. Did you delete it?
Rockbox indeed might seem a bit complex at first, just because it offers so much. My recommendation: just start small, using what you want and know about, and add to it over time. Also, SKIM THE MANUAL and note things that you might like to try/check out further and come back to later, as part of this–this helps avoid an info. overload, in my experience. As to whether having both the OF and Rockbox is complex, not really, as you use one at a time–the only complexity might be in remembering, at times, which firmware does what (altho Rockbox does more than the OF, so that might answer any question at a time)!
