i have some cds i ripped to the comp and synced them to my fuze and i can hear the music fine but can bearly hear the singing as if they were whispering in the back of a long room. it more thank likely me and my settings but if someone could please help.
Try pushing your earphone plug in . . . really hard. The plug fits extremely tight on the FUZE and several others have posted with this same symptom.
thanks for the info i’ll try that.
Could be the earbud.
I’m guessing you’re using Windows Media Player 10? That seems to be the best WMP for the Fuze. Or which software are you using? Someone using similar can help. I’ve had no problem with WMP10.
