Dear all, few months back i ordered sanddisk ssd thinking its the best ssd in the world and stored all my data in drive regarding my studies and exams and all other things such projects etc but i am unable to connect to my pc , it is not detecting my ssd i checked cable is working fine and ssd is also not damaged from outside both are in fine condition usb ports are working good so can u please help me with it because i need it , i need that that data its very imp for ,can u please help me out
Does the SSD show up in Device Manager or Disk Management?
I’m sorry to hear you’re having trouble with your SSD! Here are a few things you can try to troubleshoot:
Try a Different Port: Even though the USB ports seem to be working, try plugging the SSD into another port to rule out any issues with the specific port you’re using.
Test on Another PC: If possible, test the SSD on a different computer to see if it’s recognized. This will help confirm if the issue is with the SSD or your PC.
Disk Management: On your PC, go to Disk Management (search in the Start menu), and see if the SSD appears there. If it does, it might need to be initialized or assigned a drive letter.
Check Device Manager: Open Device Manager and see if there are any issues listed under “Disk Drives” or “Universal Serial Bus Controllers.” If there’s an issue, try updating the driver.
Data Recovery Software: If the SSD is still not recognized, you might want to try a data recovery tool or consult a professional service, as the data is important.
Hopefully, one of these steps helps you recover your data! Let me know how it goes.
You can start by checking the condition of the hard drive through Disk Management. Press Windows + X, then select Disk Management from the menu. Look for your Extreme SSD in the lower section of the window.
If the SSD appears as uninitialized, go ahead and initialize it.
If it’s missing a drive letter (such as I: or J:), right-click the drive and choose Change Drive Letter and Paths to assign one.
If the external SSD doesn’t show up at all, the problem might be related to the device itself or the connection.
You may also want to check your BIOS/UEFI settings to confirm that USB ports are enabled. Save any changes and restart the computer.
If the SSD still cannot be accessed, consider using data recovery software to scan the drive and try to retrieve your files. ( Read also: here: Hard Drives Not Showing up or Working? One-stop Guide to Fix )
