Sandisk extreme portable ssd stop working ولم يعد يظهر نهائيا ماهو الحل…؟
Hi @Nasseemsubhan,
Please refer to the article: Windows and MacOS : easystore USB 3.0 Flash Drive: Not Detected by Windows or macOS
Have you opened a Support Case? If not opened, for more information, please contact the SD Technical Support team for best assistance and troubleshooting:https://kb.sandisk.com/app/ask
That sounds really annoying. I understand how crucial it is to protect your files, particularly when using a SanDisk Extreme Portable SSD. Before concluding that the drive is irreparably damaged, there are a few things you can try.
You should start with manual checks:
- To rule out port problems, connect the SSD to another computer or a different USB port.
- Because defective cables are a common issue, use the original USB-C cable.
- To find out if the drive is detected but not visible in File Explorer/Finder, check Disk Management (Windows) or Disk Utility (Mac).
- Try mounting it (Mac) or assigning a drive letter (Windows) if it is detected but not yet allocated.
Update the storage and USB drivers on your computer.
The drive’s internal hardware or file system may be the problem if these fixes don’t resolve it. Before formatting the SSD, try using the BLR data recovery tool to recover any inaccessible files. These tools safely recover lost data by scanning the drive sector by sector. You can reformat the SSD to restore its usability after your files have been restored. The best course of action if the SSD is still not detected at all is to use a professional recovery service or contact SanDisk support for a replacement (if covered under warranty).
