Just downloaded the new, improved ExpressCache software. It doesn’t seem to fill and after maybe 30 minutes my system reboots inexplicably. I was satisfied with version 1.2.x. Is there a way to revert to the older drivers?
Try a complete uninstall of ExpressCache and clear the Temp directory then reinstall ExpressCache 1.3.0
- Uninstall ExpressCache and reboot the system
- Navigate to the following location
for 64bit system: C:\Program Files (x86)\SanDisk\
for 32bit system: C:\Program Files\SanDisk - Delete the ExpressCache folder
- Open the Registry editor: Run regedit.exe
- Go to HKEY_LOCAL_MACHINE\SOFTWARE\SanDisk and delete ExpressCache
Next we need to clear the Temp directory
- Navigate to the Temp directory (typically C:\Users|<Your logon name>\Local\Temp
- Highlight and delete all files in the Temp directory
- Reboot the PC
