Don’t you think, since people are having so much trouble with getting your products setup, maybe, it just might be a good idea to include a short troubleshooting guide with your products???
Just my opinion, SS999IL
If wrong…they have a troubleshooting guide and a support number you can call.
yea and you can check the fourms and website sansa.com
Every single question or concern I’ve ever had with my fuze has been covered usually multiple times in this forum. I had a couple of issues with my first fuze and after searching the forum for a couple of minutes; I found the answers to all of my questions. This forum is a wonderful resource, if used properly…![]()
Message Edited by fuze_owner-GB on 12-27-2008 09:21 AM
Don’t worry, majority of people should not have problems since this product is easy to setup.
Only people with problems show up in this forum, which give you impression that a lot of people have problems dealing with Sansa.
