I have a [/SanDisk Ultra 32 GB microSD HC-I card that I use in my Transformer Infinity tablet as a storage device. I had it setup as (1) 32 Gig FAT32 partition. Well I messed around with the partition on it the other day and it no longer would work. I decided to just wipe the stick and create a new 32 GB FAT32 Partition.
The thing is, now all (partition) tools I have used says it is only a 30 MB stick and in a “RAW” format !!???
I have tried:
Windows 7 (64bit) Drive Manager and get this this result:
C:\Users\John\>chkdsk /X /F S: The type of the file system is RAW. CHKDSK is not available for RAW drives.
Mini Tool Partition Wizard with this result:
Easues Partition Wizard Shows this:
I know the sectors must be messed up. I have tried a Low Level Format but it just tells me that 30MB is to small to Low Level Format. What can I do to make the 32 Gig micro stick show up as 32 Gig (fat32) not 30 MB ??
Please help if you can… I will try anything. I do not have Linux installed, but supose I could if needed.
Thanks !!!
Thibor69
