problems!!!
ive recently had a couple of problems come up…hoping someone can help-today for some reason my computer no longer "sees"my my fuze in mtp mode it sees it fine  in msc mode also when i use wmp to synch playlists the playlist shows up empty on the fuze i’m running xp pro sp3 any suggestions?
i had the same issue after updating to SP3, did you just update? you may also want to reinstall WMP11 so the MTP drivers will be refreshed.
thanks…it had been working fine after sp3 install so that wasnt the issue but tried refreshing wmp player and that solved problem…thanks a lot… i owe ya one
