Hello Sansa community.
I’ve just bought a sansa clip ![]()
And test it under linux (I’ve upgrade under win to fw29)
So here is the problem:
When i boot under linux with my clip into an usb port (with enough power) the system will recognize it and I can mount as a portable device.
But if I unmount it and try to reconnect nothing happen.
I’ve tried an other linus system (last Sidux in live CD mode, kenel 2.6.24.4) the problem is the same.
I’m now under Ubuntu 8.04 (kernel 2.6.24.13).
I’ve also tried to format the player under windows with FAT32 fileformat, same as before.
I’ve not tried with an other firmware but I’ll do it and edit this post if it works. (Fw20)
Here is my kernel log when i reput the sansa after unmount and disconnect it:
So Sansa works when I boot wit.
But if unmount / disconnect it’s no more recognized
replug:
May 24 18:30:14 UBU kernel: [2627.739873] usb 4-1: new high speed USB device using ehci_hcd and address 13
May 24 18:30:17 UBU kernel: [2631.260521] ehci_hcd 0000:00:1d.7: port 1 reset error -110
May 24 18:30:17 UBU kernel: [2631.260531] hub 4-0:1.0: hub_port_status failed (err = -32)
and rereplug ![]()
May 24 18:32:54 UBU kernel: [2787.853112] usb 4-1: new high speed USB device using ehci_hcd and address 14
May 24 18:32:55 UBU kernel: [2789.001045] ehci_hcd 0000:00:1d.7: port 1 reset error -110
May 24 18:32:55 UBU kernel: [2789.001180] hub 4-0:1.0: hub_port_status failed (err = -32)
Under windows not any problem it works perfectly (MSC mode used)
I’ve decided to post here because it could be a firmware bug.
Thanks for your reading and help.
Edit:
After a test under ubuntu Gutsy and mint (7.10) kernel 2.6.22 it works like a charm. I think there is a problem with the fw29 by communicating with new linux 2.6.24 kernel.
Message Edited by alastor666 on 05-24-2008 03:35 PM
