When I plug the Clip in the USB, I can’t find it as a drive. I can’t even charge it.
The Clip is in MSC mode.
The fw is .20.
The Linux ver. is Ubuntu 8.04.
Under var/log/messages I find:
kernel: [ 380.716938] usb 5-1: new high speed USB device using ehci_hcd and address 5
but nothing after that.
I have not used Ubuntu.
Don’t you need to mount the device before you use it?
I read somewhere to type sudo rmmod ehci_hcd in the terminal. That worked, but I have to re-type it every time I restart the computer. However, my memory cards and psp have always worked without any funny business. Whats different about the clip?
I think you need to add “sudo rmmod ehci_hcd” to a file that runs on startup, but I do not remember how to do it.
