Problem playing songs
Hello! I just bought my little Clip+ yesterday and for the most part it runs great!
But for some reason, about half or all of the songs from 4 bands I listen to won’t work. They just skip over, and if you try to play the song induvidually (like only having 1 song from an album and trying to play it), the player will crash and it has to refresh the media.
Example: Go to Led Zepplin III, play track 1: House of the Holy. Nope, skips to track 2. If track 2 doesn’t work, skips to track 3
OR
Go to Rammstein, play any song. Skips around the entire discography with a period of about 0.5 secons continuously.
I tried deleting and then re-uploading the songs, but the same problem continues.
Could be corrupted files (where did you get them?) or bad (or wrong format) ID3 tags.
I do no think they are courrupted, they run fine on my computer
What would bad ID3 tags look like?
Also, all the songs are *.mp3
