Hello there
I ’ have a problem for Formatting my micro card .
When I want for Formatting card appearance this error
guys help me plz
good luck all ![]()
Hello there
guys help me plz
good luck all ![]()
There is a switch usually on the SD cards. If you are using a SD card reader to preview the files that are on the micro SD card, there is a switch on the side that needs to be set to off.
tnx
but i havn not adaptor !
i use micro sd ram-reader to usb
so how to formatting ?
and sry i can’t speak eng well ![]()
is there anybody to help me ?
Yes. Did you click on the link in my reply and follow the advice given?
yes i did . but not worked :X tnx
Returning the device or calling Sandisk Tech Support for a warranty replacement did not work? ![]()
Obviously you didn’t because that was the advice I gave in the post I linked to. Good job wasting both yours and my time though. ![]()
Obviously you didn’t because that was the advice I gave in the post I linked to. Thanks for wasting both yours and my time though.
tnx ![]()
but it’s not possible.
because i’m persian and i can not use the warranty service ![]()
If you bought it online, and have used amazon, they accept returns free of charge usually.
Check with the seller.
Fellas,
I have 3 mobiles at home n 3 micro SD cards had problems with formatting! I use Macbook so I have been trying many things but didn’t work but it worked when I tried on Windows XP. C if it works for u too if not try other OS like Linux r windows!
It feels like hell on to u when u lose data n r u can’t copy music!
Good luck to u all!!!
KP
