Hello everyone. After the last update (06/19/2024) of your privateaccess software, I cannot open encrypted pdf files within your software. Adobe reader stays blocked and prevents opening any other pdf. I have tried on different computers with different vaults.
It seems that when you decrypt the file in the TEMP folder adobe reader cannot locate it and throws an error.
I wanted to report the bug because it is very annoying for the usability of the software.
Hi @eloy.garcia
Yes, but i dont know if somebody notify this bug to correpodient dpt.
I had the same issue.
Any update?
Up
