Can the preloaded music on the Fuze be transferred to my computer and be deleted from my Fuze and transferrsed back to My Fuze whenever I want?
I would also like to see gapless playback in the future.
Yes you may copy it off to your computer. If you are using a PC use windows explorer to open the Fuze’s Music folder and copy the files.
When I open the music, the preloade songs aren’t listed. Where do I find them on the Fuze?
Make sure your USB mode is Set to MTP mode (Settings>System Settings> Usb Mode> MTP) they should be there. If your PC wont recognize the device installing Windows Media Player 11 is the quickest fix.
Thanks! That did the trick. I was using MSC mode.
