After syncing the unit with my PC, the Playlist files show up on the player when viewing the files from the PC. But when I disconnect the player and go the the Playlists on the player, they do NOT show up.
Please explain how I get the playlists to show up on the player after it is disconnected from the PC.
I have no problems creating .m3u playlists in MSC mode on my Zip with the latest firmware. I can even convert them to .pla format if I need to in order to include songs from both the internal memory and memory card if I wish.
I asked you after your 1st post to explain how you were doing it so maybe I could help you. You have yet to give any details or respond.
Rather you’ve posted this same ‘opinion’ in 5 separate threads today. This is helping no one.
Current firmware has a playlist bug with MSC mode.
you can either use MTP mode or install the older firmware where it does work:
You cannot sync in MSC mode. That requires MTP.
The current firmware does not have any such bug.
Rather you’ve posted this same ‘opinion’ in 5 separate threads today. You are helping no one.
Rather you’ve posted this same ‘opinion’ in 5 separate threads today. You are helping no one. In fact, some might say you are just trolling.
